Not to embarass you Dan but do a search on "Fender skirt brackets".
Yes, l have a set of brackets.
Posted: Sat May 04, 2019 1:51 pm
Dick Koch wrote: ↑Sat May 04, 2019 12:25 pm
Dick, are you suggesting I don't know how to use my own website?!?
...er, I guess you are.
Oooh! Ooooooooh! You know how disappointed Matthew will be if Faulkner's not skirted at Carlisle, Dick. Can you part with them? If so, PM me what you want for them, I'll send a check back with your taillight housing.
Posted: Sat May 04, 2019 8:28 pm
A big juicy hamburger and a large Choc. Frosty at Carlisle will do. Hold the tail light, ill get it at carlisle. Will post the brackets monday.
Brackets arrived today, Dick! Thanks so much. You are a real Mensch - did I mention that?
There's a wide end, and a somewhat narrower end - it's hard for me to tell how you oriented, from this pic. Maybe, the rod on the skirt engages the bracket on the wide end?
Posted: Fri May 10, 2019 7:28 am
I never noticed that, l would say the final position of the rod would be the small end if it fits. It should have a rubber dampner on it.
Posted: Mon May 13, 2019 8:09 pm
Faulkner's painted, and home!
Not a bad color match, eh?Martha, booted to the curb, AGAINSafely ensconced, where Faulkner belongsOh no! The passenger side hinge a spring took a hit. I'll have to touch that up. Mostly, this is just shop dust that has to be cleaned up
I really love how it came out - although, there are a couple spots that need some 2000 grit blocking and polishing. I talked to the owner, he's going to fix it when I drive it back after all the lights are hung.
All I need now is a minor miracle, to put this all back together before Carlisle. But it's still in the low 40's and raining like a sumnabitch here. This is like no spring I have ever seen... (*tap*, *tap*...) Hello Matthew, is this mike on?!?
Posted: Tue May 14, 2019 6:53 am
Holy crap, that looks good!!!!!!
Posted: Tue May 14, 2019 1:05 pm
Man, l cant wait to see those skirts on him.
Posted: Tue May 14, 2019 3:08 pm
That’s funny - Matthew said the same thing
Posted: Tue May 14, 2019 7:02 pm
by william0431
WOW that turned out beautiful!!!! you will get it put together in no time I bet! Gonna look amazing once the trim is on. That was a fast turn around time for the body shop!
Posted: Tue May 14, 2019 10:06 pm
Dan: All I can say is WOW !!!! That looks real fine !!!!!!!!!!!! Mark
Posted: Wed May 15, 2019 11:11 am
Looks great, Dan!!!
Posted: Sat May 18, 2019 10:08 am
Oh Noes! I'm going through my Gary Goers stash - and my taillight bulb sockets are too big! They're 1", and they should be 3/4"...
Anyone know a good source for these? I need four single terminal, and two double terminal.
