Dash Pad & Brake Vacuum
I have two questions.
First, this car appears to have come with a padded dash (see pic). Does this piece just clip on? What does the framework look like (I seen pictures of the actual pad). Is this a piece I may be able to find and restore, or will I need to look at fabricating something, or possibly have to go all George Barris.
Second, the vacuum lines for the power brakes obvious are not original (notice the check valve). I've noticed many of the cars with power brakes have a two hole canister, but I haven't seen any with the single, with the canister actually connected. Was there just a simple T-connector? surely it looked cleaner then what I've got going.
Vrooomm, Dugga, Dugga.
I have the same style of canister, with a single input line and a check valve.
And Roger's right about "Just Dashes" -- although, I think for that price, they expect you to provide the internal band so they can make a dash pad for the next guy! I've get to take my makeshift pad off, to see if I have the original band under there...
Hi - I just received a new dash pad from Just Dashes www.JUSTDASHES.COM It comes black for $400.00 if you want a color thats another $100.00 freight to Florida was $35.00. It is very nice. You do not have to send them anything, no original pad or metal pieces. It comes with a bottle of glue to glue to the dash.
My vacuum canister has two hose outlets, one with a check valve running to the rear of the intake manifold the other running to the power brake chamber.
Hopes this helps.
Hopes this helps.
The old dash pad I had on my car was done by a local upholsterer, not bad but not original and there was no metal strip, but when I ordered the new one from Just dashes they did not even ask for the metal strip, I asked them about mounting the new one and they said you just glue it on.
Dick ,
Thats great!
I was going into the dash section and they didn't have it listed, sure as **** the way you sent me in. They do have them and even a nice picture to drool over!
Thanks!
For anyone else hitting the same road block as I did, here is the direct link.
http://www.justdashes.com/ProdGallery3.htm
Thats great!
Thanks!
I can't answer that question because the one I had on my car was made by a local upholsterer with sewn seams not moulded like the original. He then glued that one on so I had no clips or metal strip when I took it off.
The just dashes pad is moulded like factory and covers everything when you glue it on.
