Fuel Sender On Ebay - Quality?
John
Post by John »
Hello - I found a 59 Plymouth Fuel Sending Unit on Ebay. The link is attached. The last time I post someone said these were "suspect" at best. Does anyone have any experience or opinion about this unit and or compatibility and reliability? Thank you! John :shock:
http://cgi.ebay.com/ebaymotors/Mopar-57 ... enameZWD1V
Guy Salmon
Fuel sender
Post by Guy Salmon »
John
I bought one of these from the same vendor. Basically it didn't fit so I used bits off it to fix the old one. It wasn't worth returning cos I'm in the UK. I did query with the vendor after I'd tried fitting the new unit but never got a reply.
Does this help? I suppose if postage is cheap enough to return then you may consider it worth a go.
Guy
John
Thank you
Post by John »
Thank you for offering your experience Guy. I am still considering buying one though as there is nothing else out there I believe. Does anyone else have an opinion or experience? Thank you. John :?
Hi John - Check with Neil Freman at: www.fremanauto.com.
John - Scratch above. Make that: www.fremansauto.com
vhandyman
Re: Fuel Sender On Ebay - Quality?
Post by vhandyman »
Hello John,
I know that this is an old e-mail of yours but I too am looking for a fuel sending unit. Where are they and how do I find one.
59 fury Johnnie J.
Search thru Vendors section on this List. Van's Auto reportely is selling them.
vhandyman
Post by vhandyman »
rogerh wrote:Search thru Vendors section on this List. Van's Auto reportely is selling them.
Thanks, but on this list ?? were is this list ?? Johnnie
vhandyman wrote:Thanks, but on this list ?? were is this list ?? Johnnie
Over in the Vendors Forum, Johnnie -- here's a link. Don't forget to click on the picture to render it full scale, if you have trouble making out the description or contact info:
https://59plymouth.net/59forum/viewtopic.php?f=6&t=1155
