My 59 plymouth savoy is for sale
safetymike1977
Post by safetymike1977 »
For sale: 1959 Plmouth Savoy
4 door sedan
Rust free South Dakota car, looks and drives great
Originally a 318 Poly. Now is a 400 Chrysler.
New parts:
Engine has all new bearings and rings, seals.
New Lunati Voodoo Camshaft/lifters
Mopar performance chrome valve covers
March performane serpentine pulley kit
Chrome alternator
Flex fan and electric helper with thermostat
Water pump, fuel pump, oil pump
Mopar performance electronic distributor
Taylor stainless steel wires
Jacobs Electronics ignition
Weiand Intake
Edelbrock 750 CFM performer carb
Hedman shortie headers
New header back 2.5 inch aluminized exhaust
welded seam Flowmaster 40s
Recently rebuilt pushbutton trans
Brand new custom built slip yoke driveshaft
Radiator redone last year
Fuel tank etched and lined inside, blasted and lined outside
Front disk brakes by AAJ
Rear disk brakes by AAJ
Dual master cylinder
Tires are 2 years old, maybe 10,000 miles on them at the most
Heater core was cleaned and pressure tested
Interior is EXCELLENT, as far as upolstery.
Rear package shelf could use some vynl die
Some knicks in the paint on the dash
Dash pad has a couple cracks, but not bad
Windlace has some worn spots, believe it is original, as is the window weatherstrip
Door weatherstrip was replaced at repaint, but with incorrect parts. Works though.
Just replaced the trunk weatherstrip
Has had seatbelts installed in the front. Look like they belong.
There is a small hole 1 inch square hole cut in the floor and mat for a shifter, but it is no longer
needed since the trans is a pushbutton trans.
Paint is candy apple green. Still in great shape, but I have driven it a lot, so there are some knicks.
Front lower valance is dented, but there and in good shape otherwise.
Bumpers are slightly bent, but good for now with decent chrome. Has optional bumper guards.
All glass is perfect, it is tinted glass.
Front suspension parts are all in great shape. No slop.
Power steering gear and pump are both rebuilt.
Needs:
Carpet, Transmission mount (available from imperial services)
3/8 fuel line, currently, I am running with 5/16
Extra parts included:
Complete 3X2 setup. Includes Offy intake, adapter plates, 3 new vintage speed hot rod silver
rochester 2 G carbs, 3 air cleaners, fuel block and lines, linkage.
Extra set of 4 tires. Raised white letters, brand new.
A couple spare trim pieces.
Asking $10,000 for all of this. You can drive this car ANYWHERE. Only old driveline parts left are the
brake booster and the rearend.
safetymike1977@yahoo.com
920.203.6853
