Trim needed
eroomas
Trim needed
Post by eroomas »
Hey Guys, I need the upper piece of passenger side door trim for a 4 door fury. The piece measure 5/8" by 43" long. Thanks in advance.
Re: Trim needed
Andy, did you try John Fowlie (Big M Auto)? Also, if you can dig up the P/N, you might find NOS from Glen Dawson or (*gulp*) AMS Obsolete (formerly Frank Mitchell, very pricey...)
If I can find time this evening, I'll try to look up the part number and run it for you.
eroomas
Re: Trim needed
Post by eroomas »
Thanks Dan, I tried Big M that was a no go. I'll try looking up the number
Re: Trim needed
Andy, from what I can see - this is the part you need (even number, for the passenger side):
Unfortunately, I've searched my online sources for NOS, but I'm coming up empty. Dick Koch has been known to fashion replacement trim from other pieces - I wonder if he could help you out? Not before he finishes Martha's trim, though! :roll: :P
Re: Trim needed
Hold the bus! You need the front door passenger side upper - I searched for the back door.
AMS has it! Search for P/N 1846742. Gawd knows what they want for it though:
eroomas
Re: Trim needed
Post by eroomas »
Thanks so much Dan!
w.weiland
Re: Trim needed
Post by w.weiland »
I believe I got a NOS one will check tonight
