horn wire
LEONARD
horn wire
Post by LEONARD »
On the 59 does the horn wire go through the steering box to the horn's?
Re: horn wire
Leonard; not sure what you mean, there is A piece of copper strip at the rubber insulator where it connects the steering wheel shaft/pin to and at the steering box to complete for ground, steering box to frame, bolted etc. Horn works when ground is complete. Mark
LEONARD
Re: horn wire
Post by LEONARD »
What i was meaning does the horn wire go down the center of steering and come out bottom of steering box like it does on a 55.
Re: horn wire
Leonard; goes down the center of the steering tube and plugs in A harness at the bottom. I think the horn wire is black in color and goes to the hi tone horn at the radiator core support. Mark
LEONARD
Re: horn wire
Post by LEONARD »
Thanks Mark
