Stainless Trim ?
Stainless Trim ?
I am looking for the upper(thin) rear left quarter panel stainless trim for my 4dr.Fury sedan.Mine is probably beyond repair,the end foot and A half or so is pretty flattened,something must have rubbed against it at some point in it's previous life,I don't think I can fix it.The bottom one is the wider one I need the upper one,it has A radius to it. Thanks Mark
Re: Stainless Trim ?
I just may have it, give me the width and length.
Opps, provided it's the same as a Belvedere.
Dick; I think it is the same,I will measure it when I get home this afternoon,thanks Mark
Dick; the trim is 48" long x 5/8" wide. It's the peice just below the gas filler lid.I measured from the screw tab that screws into the pass door opening to the striaght end that gets overlapped by the trim peice with the double into one, ahead of the tail light. Thanks Mark
Mark - Sorry, I don't got the one for a Fury. I have both sides for a Belvedere and they measure 44-5/8 inches long. Its part #1865842. The one you want is part #1950380. Page 23BJ in the parts book. If you are real nice I can tell you where to get 2 of them, probably NOS. It's deception pass auto parts, Len Dawson.
See attached,
http://www.dpmotorparts.com/inventory_4_b.cfm
See attached,
Dick:It's not the one but I grabbed it anyway.Mine is the upper narrower one part #1846745.He don't have one,also picked up A front door lower(wider) one. Thanks anyway Mark
My bad, I must have been standing on my head when I read your post. Well at least I got you on the right track. Sorry.
Mark - Check with John Fowlie at BIG M.
