Ball joints
Ball joints
I was messing with my brakes I took one side down to just the spindles and it feels like it wiggles up and down could this be the ball joint how do I replace them and are they pressed or screwd in.
Re: Ball joints
They are screwed in,soak em up good with some penetrating oil.You will also need the socket that goes on an impact gun or breaker bar.I got my socket(tool loaner )from advance auto,or try A NAPA store.Do A "search"(ball joint) on tech support and check out an old post,maybe mine is up there. Good luck Mark M
