59 Plymouth turn signal cam/pawl
Hello, I need a turn signal parking pawl/cam for my Sport Fury. It's the part that attaches to the switch & turn signal lever. It fits the above column.Thanks
Re: 59 Plymouth turn signal cam/pawl
You only need the top part or do you need both?
I don't think I have any spares but I will look.
Here is (I think) the top part
http://m.ebay.com/itm/311144214565
Hello, Matthew. I should only need the top part. I purchased one similar to the ebay part, but it does not fit. As you can see in my pic, there is a metal piece protruding from the bottom of the column, so it would need to account for that.
Horn relay ground follower?
Yep, that's it.RICKYMOPAR wrote:Horn relay ground follower?
I am looking through my goodies for one this evening.
I no longer have a turn signal switch for a 59 Plymouth.
Thanks for looking.
