Aftermarket 4 barrel Intake
Re: Aftermarket 4 barrel Intake
Kiwi, A performance manifold with no carb heat. Air gap to send a cold charge to a hot engine.
Yes performance intake but was more the aspect that someone has started making some aftermarket gear for the poly engines. $595 us for a brand new intake is not badly priced when comparing what people want for the original cast iron 4 barrel or dual 4 barrel manifolds and, in my instance, a hell of a lot cheaper to freight over here. Just need to work out if it isnt so high that it will all fit under the bonnet
Kiwi - Check out this site for 318 aftermarket performance stuff.
https://groups.yahoo.com/neo/groups/318poly/info
