Bellows brake booster.
Posted: Sat Apr 19, 2014 12:00 am
Hi guys. I have to replace the brake booster on my Belvedere. Reading the Service manual it says wedge brake lever??? and undo booster from brace bracket. Do you need to undo the and remove the brace bracket to do this? or can it be done with the bracket in place. Looking at it there is a nut either side of the bracket that lock the booster in place. If the bracket needs to come right off do I need to remove the master cylinder to do this or not. Any advice appreciated. Robbie.
