brake problem
brake problem
my brakes work fine but if I let my car sit for a few days the petal goes to the floor then I pump it and its fine again. I have no booster so what else could it be did the brake petal have a spring down there to hold it from slowly settling to the floor.
Re: brake problem
Martin - If you are loseing your pedal you should be losing brake fluid also. Have you checked the master cylinder?????
Re: brake problem
If you are not losing fluid, the master cylinder would be the primary suspect.
Re: brake problem
Not losing fluid its a brand new master cylinder
Re: brake problem
Sorry to say, but if your pedal loses "resistance" over time, the master cylinder is leaking internally. Yes, you have a new one, but I will say it is no good...gert another one..
