Power Brake Booster Question/Help
Posted: Thu Jul 04, 2013 3:05 pm
Happy 4th of July; I have the cannister brake booster off and am trying to track down the hissing/sucking sound when I begin to apply the brakes.The motor will also idle A little rough when stepping on the pedal,but otherwise everything works as it should,seems to stop ok,and the motor resumes to A nice idle after the pedal it released,must be A vacuum leak.Does anyone know where to get A rebuild kit for the booster,I think I can do it,doesn't look to difficult.Has anyone had A rebuilder do it,if so how much?And who does it? I have discovered A broken spacer(plastic) sandwiched between the booster plate and the retainer/gasket,it would face the fire wall and it might be the source of the sound.Has anyone ever ridden one of these animals,Dick,Roger,John? I am also going to replace the master cylinder,it don't look to difficult. Thanks Mark M
