1959 Plymouth Belvedere
Hi. I am looking to find the Belvedere script that goes on the drivers side rear fin for a 1959 Plymouth Belvedere. I am located in SK Canada. Thanks John
Re: 1959 Plymouth Belvedere
John, good to see you found your way here too!
John Q might have something, John F (BigM) must have something
I do not have any spares but have just seen some on E bay, I will try to find that auction again.
John Fowlie, at Big M Auto salvage, Williams, CA http://www.bigmauto.com/ is your best bet. Here is his phone number too! (530) 473-2225
He ships to your providence in Canada I believe. He is a super guy and has a 59 Plymouth SF convert to boot!
Tells us more about your car! 2 door or 4 door or even a super rare and sought after Convertible like mine!!
Hi. My car is indeed a convertible. I purchased it about two months ago and am in the process of collecting all the missing parts. The car was built in Evansville . It was originally powder blue. It was previously painted black and reupholstered black and white. I intend to redo it in the original colors but will need pictures of an original to go by. The total power train was missing. The frame and floors are solid and almost rust free.There is rust around the rear wheel wells and head lights. There is so much to tell and also so many questions to ask. You all will definitely be hearing more from me. John
Outstanding! Another Belvy convert! Check out the thread on "Show your Ride" on the Board Index and check out my journey of "Colorado Belvedere Convert Progressing"
Also check out Dick Koch's current Belvy convert restoration in the same thread. "Dicks Convertible Project" Also Tom Fox, in the showcase section, has a near perfect Belvedere Convertible that I followed as close as I could to it. I took over 50 pictures of his car when he came thru Denver a few years ago. His car showed me an end point and lots of details to pursue.
I was almost to Saskatchewan southern border when I picked up my convert in Montana. Mine is a Evansville car too! Originally black but I painted it the Spring Special Turquoise instead when it was time to paint it. And upgraded to the optional swivel seats and a SF style of interior(not available to Belvy's in 59) but kept the Belvy external side trim. Kinda a "one of none" build...
Look forward to seeing what you have and your progress on it. Start a thread on the "Show your Ride" like I and others did to follow your progress.
Last edited by Denver 59 Fin Convert on Fri Dec 28, 2012 10:21 pm, edited 1 time in total.
There are original repair parts for the wheel lips and rear quarters available on E bay and also the repair parts for the headlight areas so those parts on your car can be repaired.
I do have both sides of those scripts around somewhere, they are somewhat pitted though, let me know if interested.
Bob
Bob
Hi Bob
Yes I could be interested. How bad are they? Do they still have the mounting pins attached ? What are you asking for the one drivers side? I was hopping to find a nice one but could see if I could get this one replated. Thanks John
I'll look for them today and let you know, they do have the mounting pins on them, they were the ones that were on my 59 Plymouth when i got it in 04, and i found a very nice set on ebay to replace them with.58 coronet wrote:Hi Bob
I'll get back to you ASAP.
Bob
Well, i found them easily enough, theres no difference as far as which side of the car they are mounted on, they both have some pitting and would be good for a "driver", or if they are missing!
One does have the center mounting pin missing though, if you're still interested I'll take pics of them if you like.
Bob
Bob
Hi. Well you learn something new every day. I thought there was a left and a right but you are correct there is not,they are both the same. That is a good thing because it should be easier to find one good one. Yes please send a picture Thanks John
Hi John, heres how they look....let me know if you like what you see.
Bob
Bob
Hi. Yes they are pitted quite badly. I will hold off for a while in hopes that something better will turn up. You never did say what you wanted Thanks for now. John
Oops, sorry John, if you want them I'll take $15 plus the shipping costs, let me know if you do.
Bob
Bob
I don't spend much time on EBay anymore...I have not learned the filter system, so I don't get all the car cover ads etc.
Moreover, I no longer have my Plymouth, but if you can learn the filter system, I should think there would be at least several listings of "Belvedere" scripts on eBay. IF not, you can search the NOS suppiers, such as Len Dawson.
