Auto Headlight Dimmer Wanted
Mark Evans
Post by Mark Evans »
Does anybody have a Auto Headlight Dimmer Setup the want to sell ?
Mark Evans
Re: Auto Headlight Dimmer Wanted
While I don't have an Autronic Eye to sell, I do have the following information on them.
Forwardlook Frank (where he is he now?) told me the base to which the Plymouth Eye mounts is maybe an inch SHORTER than the Imperial ones you can still find in salvage yards. He was my source for the correct base. This unit is now on the Keij car. I got the Eye out of a 1960 Imperial. The "brain box" mounts above the driver's kickpanel. Matthew Keij should still ahve the factory instruction sheet I sent along with the car.
Mark Evans
Thanks Roger
I will ask Matt to send me a copy.
I found the Part Nos on page One of the Parts book
The base is listed as 1971156 , Looks like the setup has 4 parts , Control unit , base , Scanner, Spacer
I assume I can make the wire Harness.
Will keep looking
Mark
