radiator
Posted: Thu Aug 16, 2012 9:34 am
by martin59
Would my stock radiator work on 73 engine or would i have to use a radiator the same year as the engine
Re: radiator
Posted: Thu Aug 16, 2012 10:49 pm
Should work. The mounting holes locations from one radiator to the other may be different. So you may have to drill some new holes. If the newer radiator comes with a shroud,use that too!
Is the outlet and inlet on both radiators the same location?
Re: radiator
Posted: Fri Aug 17, 2012 6:46 am
Using the old water pump would have the lower hose connection on the correct side. You can use the old radiator. 1969 and earlier water pump.
Re: radiator
Posted: Fri Aug 17, 2012 11:09 am
by martin59
Thanks guys im still learning. Im glad i found this place thanks.
Re: radiator
Posted: Mon Aug 20, 2012 12:50 pm
by martin59
Would my transmission cooler line work good on the radiator to or should i just buy a separate trans cooler radiator. My water pump exits on the opposite side that the radiator does. Im just trying to work with what i have. Thanks for the advise guys
Re: radiator
Posted: Mon Aug 20, 2012 7:19 pm
The lines should work as long as the coupling nut on the tranny cooler lines are compatible (i.e. same size) , If you have a flare nut wrench make sure you use it so you don't round out the fitting. Did you have that newer (old ) radiator checked out before you put it in? As long as you have it out, I would take it by a radiator shop for a pressure test and clean out.
Just cheap insurance...to do it now.
