where is the vin tag located
martin59
Post by martin59 »
Where is the vin tag located is it on the driver door or on the fire wall on a 59 Plymouth belvedere
Re: where is the vin tag located
I think different mfg plants would place it on the lower drivers side door frame (Lower A pillar) On my Belvedere convert is on the upper firewalll above the Power brake booster.
My car was built in Evansville, Indiana. Some car have build or fender tags but my convert does not have one at all.
Some of the other guys will have to chirp in here for a more definitive answer on different plant locations.
It should be in the door jamb or on the firewall right above the brake booster.
It's also possible that the VIN is on the data plate and then it's on the firewall, should be on the drivers side next to the master cilinder
