Oil for dist. & Gen
Oil for dist. & Gen
Good day!
What type of oil should I be putting in the little oiler tubes to the distributor and generator?
"Oldschool is cool"
Ernie D.
Ernie D.
Re: Oil for dist. & Gen
I use the same oil I use in the engine. Any good grade oil works.
Information from the Lubrication Chart on p. 496 the 1957-8 Plymouth Service Manual:
For the generator and distributor,... SAE 10W.
Speed takes "speedometer oil"
The cable takes "speedo cable lube".
Power steering uses Type A tranny fluid.
..my 2 cents...
..my 2 cents...
