tune up
tune up
Hello,
Although the engine in my car is a '61 Chrysler 361, perhaps the carb adjustment is similar to the '59's...If I turn the mixture screw all the way clockwise until it seats, how many turns counter-clockwise do I turn it until I have a good mixture? (I have forgotten how to tune these engines!).
Roger
Roger
tuning a 61 chrysler engine
Roger,
The screw you speak of is, in fact, the IDLE screw...the IDLE screw only affects the idle. Seat the screw, then turn it out 1 1/2 turns. Warm up the engine, and then back out the screw until the engine starts to bog down. Turn it back in a bit, and you're done.
Your troubles with acceleeration are related to vacuum advance and accelerator pump in carb. Look into it!
signed,
your conscience
signed,
your conscience
Re: tuning a 61 chrysler engine
Ha! OK, so the board's a little sluggish in getting off the ground...rogerh wrote:...signed,
your conscience
