Page 1 of 2
BRAKE LIGHT SWITCH
Posted: Sun Jul 04, 2010 6:16 pm
Okay, my memory has gotten as rusty as a Plymouth in the 6 years since my car was restored. Right now my brake lights don't work. There is power to the switch, if I unplug and cross wires, the lights come on. This tells me the switch has failed. What is involved in replacing it? If I un-screw the switch, will the M/C drain out, necessitating a bleed of all brake lines?
Several people have recommended I "simply" add a modern switch inside the car, under the dash, activated by the brake pedal arm.
First I hope to learn the answer to my first question. Then I would appreciate any tips on adding the modern under-dash switch (what manufaturer, what location to mount switch). :?
Re: BRAKE LIGHT SWITCH
Posted: Mon Jul 05, 2010 9:32 am
by Fins59
My memory is rusty too. I replaced these pressure brake switches years ago and I don't think brake fluid leaks out but I can't remember either.
On the modern brake light switch; I have one on my car. I want to say I got a '70's volare switch but not sure or I got a universal push button type for a couple bucks. It just has a button on it that the brake pedal arm contacts. I think it was on the "Help" rack in the auto parts store.
What I did is made a bracket that new switch is attached too and then attach bracket to something near brake pedal. You gotta make sure brake pedal arm makes good and correct contact with switch button, so what I did is C clamp the assembly to a piece by the brake pedal. That way you can move it around to find good contact before you drill holes and bolt it.
I just went out and looked. Switch is still C clamped. It's just a small, maybe, 1" C clamp. It works so good I left it that way :D
Posted: Mon Jul 05, 2010 2:15 pm
YES, FLUID WILL LEAK OUT. But not really a big deal, use shop towels to keep the DOT3 off the finish. be quick and you may not have to bleed the system. If some fluid did splash on your paint. Just wipe it down with a wet cloth. and also dry the area.
Posted: Mon Jul 05, 2010 7:49 pm
Ahah, thanks Rick!
Posted: Tue Jul 06, 2010 11:36 am
by Fins59
Roger - I did my monthly check of FWDLK email and on 6/28 they're talking about brake light switches. You might want to check it out. Something about different threads, etc. and one person uses a Harley Davidson switch??? Do that, and then a person can amaze a Harley guy by telling him "I've got Harley parts on my '59".
I've got Chevy parts on my '59 (Monte Carlo brake calipers and hoses, I believe, thanks AAJ :D ) but I don't tell anybody :wink:
Posted: Tue Jul 06, 2010 11:42 am
Roger,
More often than not, after changing the switch you will introduce a small amount of air into the master cylinder. Generally, this will bleed out by simply pumping the pedal several times. The original switches are getting harder to find, different diameters where the unit screws on, and an adaptor fitting may have to be used. Some folks are converting to a mechanical switch, those from early '60's Mopars seem to work quite easily from what I have been told.
Posted: Sun Aug 01, 2010 4:01 pm
by Nighthawk
Funny that this question is here, i was away for a week and when i went to start the Plymouth, the battery was totally dead, to the point that it wouldnt even take a charge, after getting another one i found my brake lights to be on, further investigation showed that fluid is leaking for the stop light switch, so am i to understand replacing the switch will solve this??
Bob
Posted: Sun Aug 01, 2010 4:23 pm
Bob,
probably a typo, did you mean to say fluid is leaking FROM the brake light switch?
This would be odd, as it is a sealed unit.
Do some more investigating, and get back to us. I have a NOS switch here I would be happy to sell you for my cost!
Posted: Sun Aug 01, 2010 4:30 pm
by Nighthawk
rogerh wrote:Bob,
Yes it is, i can see it dripping down from the switch, i unhooked the wires and found them to be wet.
Posted: Sun Aug 01, 2010 5:45 pm
Okay, to me that's wierd, because that means the plastic innards of the switch have failed. With our cars, anything is possible!
I'm worried that sediment in your car's lines or reservoir have clogged the switch, causing it to stay "on", then maybe the pressure of one more pedal push cracked the weakest link.
I'd recommend you flush the reservoir, and replace the switch.
Posted: Sun Aug 01, 2010 9:06 pm
by Nighthawk
rogerh wrote:Okay, to me that's weird, because that means the plastic innards of the switch have failed. With our cars, anything is possible!
I'm worried that sediment in your car's lines or reservoir have clogged the switch, casing it to stay "on", then maybe the pressure of one more pedal push cracked the weakest link.
The odd thing is that talking to other "old" Chrysler guys, they've never heard of this happening. the master isnt that old, but the switch is older, it was on the car when i got it and when the master went in 2006, the same brake light switch was used, but ill see about getting another switch tomorrow and I'll let you know what happens....
Bob
Posted: Mon Aug 02, 2010 8:48 am
Bob - I get those switches from the local NAPA dealer.
Posted: Thu Aug 19, 2010 10:28 pm
what was the outcome of this?
Posted: Fri Aug 20, 2010 1:04 am
by Nighthawk
lol, you know i forgot to put an update about this on here......
No one around here (parts stores) had the switch, and the guys that i call when i need something like this were all on vacation, so at a local cruise night some of the guys had noticed that they hadnt seen my Plymouth recently, i usually drive my Chev 1 week and the Plymouth the next week, so i told them about my dilemma and one of them said, i may have one of those at home, sure enough the next day he brought it to me but i had to get an adapter for it, so this problem has been fixed since last weekend, funny thing since, all the parts guys that i either called or emailed came back from vacation and of course they all had the switch available!
Also, i did find out that its not uncommon for the switch to develop a leak such as mine did, but everythings fine now and i didnt have to bleed the brakes either!
Bob
Posted: Fri Aug 20, 2010 1:12 am
I was curious, so I put my old switch in the vise and tried to develop a crack in it.
Not possible! So I am baffled how your switch developed a leak. Myterious.
