Power Window Assembly For Convertible
vic barone
Post by vic barone »
Hi All
A little while ago i bought Chuck Hazelton's Cvt and had it shipped to Australia. I also have a restorer Sport Fury hard top that has power windows.
For those of you who might be interested I am trying to convert my manual winder windows (in the CVT ) into a power window assembly by using those from the hard top
From what I can see so far it turns out that the convertible set up is just a mirror image to that of the hard top. This together with a slightly more kinked arm. ( I have been able to make this comparison as I have a mate who is currently restoring his CVT that has the power window assembly)
I have noted that if I use the maunal winder arm with the power window assembly cog and mounting bracket I should be able to get it to work
I will post some photos to show the differences soon.
Any feed back or experiences on the matter will be greatly appreciated
Cheers
Vic
If I read you right, you are attempting to fit a power window motors to manual tracks. A talented fabricator could conceivabely do such a thing...welding stuff, cutting metal parts, all that...I wish you all the luck!
