Page 2 of 3
Re: 59 Plymouth Convertible courtesy lights
Posted: Wed Jul 24, 2013 12:50 pm
by 58 coronet
Hi Mark
Sounds good. Do you know if Garry G is well yet and still in business? Thanks John
Posted: Wed Jul 24, 2013 12:54 pm
by 58 coronet
Hi Mark
Sounds good. Do you know if Garry G is well and still in business ? Thanks John
Posted: Wed Jul 24, 2013 4:19 pm
Mark - I got my top well and boot from Gary Goers. Glad to hear the top well fit good.
Posted: Wed Jul 24, 2013 5:20 pm
by Mark Evans
John,
Gary is behind but still working,Send a Fax with your Parts Nos. and they will get back to you.
You need to tell him the Color you want.
Mark
Posted: Thu Jul 25, 2013 9:58 am
by 58 coronet
Hi Mark
You mentioned that I could Get a courtesy light wiring harness from the source in Canada. I am not finding the source. If you could come up with a name I will try it. Thanks John
Posted: Thu Jul 25, 2013 11:02 am
John - Do a search above on "Wiring Harness"
Posted: Thu Jul 25, 2013 12:57 pm
by 58 coronet
Hi Dick
I did search prior to asking. All I found was a US supplier . A Canadian Supplier may work better for me if there is one. Thanks John
Posted: Thu Jul 25, 2013 2:56 pm
by Mark Evans
Guys , Here you go.
My complete Harness was perfect, Every wire has the NOS correct connector and is labeled where it go, also comes with a complete set of Instructions .
Mark
PS , Should have my car back over the weekend
GREG LEGGATT, 8738 County Road 2, Napanee, Ontario K7R3L1, CANADA. leggatt@kos.net Phone 613-354-2712.
Photos of 59 Plymouth Convertible courtesy lights
Posted: Wed Jul 31, 2013 9:11 am
by Mark Evans
John,
I just Picked up my SFury and was able to take some photos of the rear seat and the Side light fixture below.
I need to make a few adjustments to my rear seat, so I have not removed the panels yet. I have attached the same setup in a Yellow Dodge for Ref. that was at Carlisle.
Let me know what use you still need besides the Dims. of the Panel hole location , which I will post tonight. and I will post what else you need.
Did you get in touch with the Harness supplier ?
Sorry for the Dups ,I could not figure how to remove
Mark
Posted: Thu Aug 01, 2013 12:14 am
by 58 coronet
Hi Mark
Thanks for the pictures. They will be good for reference as I go along.The part I was really interested in was how the bezels snap on. It looks like there are little pins inside the socket that they snap over. It will soon be clear. Yesterday I was lucky as I purchased a pair of sockets from Murry Park and I hope they are on there way. I do still need to know the location on the pocket. I tried contacting Greg Leggatt by Phone several times but no answer. I am sure we will connect one way or the other. I have just been to busy farming but I am making progress. After Oct.I will be able to spend more time on my Car. I do hope that when Your car is finished you and others like John Q will still be available to answer questions. Your help is greatly appreciated. I need to figure out how to add a picture. John
Posted: Thu Aug 01, 2013 8:14 am
by Mark Evans
I will get the side panels out by tomorrow and take the light locations
Does anybody know of another Wiring Source?
Posted: Thu Aug 01, 2013 10:45 am
by 58 coronet
Hi Mark
YnZ is another source for wiring. They are out of California. Just Google YnZ and they will come up. I talked To Greg Leggatt of Ontario Canada this morning . He has or can make up the various wiring harnesses for my 59 Ply convertible.
Main harness-495.00 tail light including top motor wiring- 210.00 courtesy light harness 30.00 That should cover my car. John
Posted: Thu Aug 01, 2013 9:34 pm
58 Coronet:
You are correct...there are two dimples on the interior of the light socket (can be seen in above photos) which hold the lens bezel in place.
Posted: Fri Aug 02, 2013 5:19 pm
by Mark Evans
John,
The holes for the lights in the Rear side Panels are located as follows:
The hole is 1 1/16" in dia.
The first photo Dim is 2 7/8" from the Horz. shelf as shown
The 2nd photo Dim. is 3 3/4" when you wrap with the contour as shown.
The last photo show that the panel is Dimpled about 1/8" in to except the flange of the socket, This can be hard to do, you might just try mounting it flush or you could put a little padding under the vinyl to make up for the flange?
If you need anything else ,just ask
Mark
Posted: Sat Aug 03, 2013 12:49 am
by 58 coronet
Thanks Mark. That explains a lot. I could not see not how the socket could mount on the curved surface but that dimple as you called it gives a flat surface to mount to. I think I can duplicate that. I will wait until I receive my sockets before I try. I had to make the left pocket as it was missing and that was quite a challenge. I will need some information on the well as it was also missing. I think I should start a new thread for that in the near future. You could take some pictures of the well from all angles while you have it opened up. I don't know how to include a picture but will try including one of my home made pocket. ( for practice)
