59 Plymouth Convertible courtesy lights
Re: 59 Plymouth Convertible courtesy lights
Hi Mark
Sounds good. Do you know if Garry G is well yet and still in business? Thanks John
Hi Mark
Sounds good. Do you know if Garry G is well and still in business ? Thanks John
Mark - I got my top well and boot from Gary Goers. Glad to hear the top well fit good.
John,
Gary is behind but still working,Send a Fax with your Parts Nos. and they will get back to you.
You need to tell him the Color you want.
Mark
Mark
Hi Mark
You mentioned that I could Get a courtesy light wiring harness from the source in Canada. I am not finding the source. If you could come up with a name I will try it. Thanks John
John - Do a search above on "Wiring Harness"
Hi Dick
I did search prior to asking. All I found was a US supplier . A Canadian Supplier may work better for me if there is one. Thanks John
Guys , Here you go.
My complete Harness was perfect, Every wire has the NOS correct connector and is labeled where it go, also comes with a complete set of Instructions .
Mark
PS , Should have my car back over the weekend
GREG LEGGATT, 8738 County Road 2, Napanee, Ontario K7R3L1, CANADA. leggatt@kos.net Phone 613-354-2712.
Mark
Photos of 59 Plymouth Convertible courtesy lights
I just Picked up my SFury and was able to take some photos of the rear seat and the Side light fixture below.
I need to make a few adjustments to my rear seat, so I have not removed the panels yet. I have attached the same setup in a Yellow Dodge for Ref. that was at Carlisle.
Let me know what use you still need besides the Dims. of the Panel hole location , which I will post tonight. and I will post what else you need.
Did you get in touch with the Harness supplier ?
Sorry for the Dups ,I could not figure how to remove
Mark
Hi Mark
Thanks for the pictures. They will be good for reference as I go along.The part I was really interested in was how the bezels snap on. It looks like there are little pins inside the socket that they snap over. It will soon be clear. Yesterday I was lucky as I purchased a pair of sockets from Murry Park and I hope they are on there way. I do still need to know the location on the pocket. I tried contacting Greg Leggatt by Phone several times but no answer. I am sure we will connect one way or the other. I have just been to busy farming but I am making progress. After Oct.I will be able to spend more time on my Car. I do hope that when Your car is finished you and others like John Q will still be available to answer questions. Your help is greatly appreciated. I need to figure out how to add a picture. John
I will get the side panels out by tomorrow and take the light locations
Does anybody know of another Wiring Source?
Hi Mark
YnZ is another source for wiring. They are out of California. Just Google YnZ and they will come up. I talked To Greg Leggatt of Ontario Canada this morning . He has or can make up the various wiring harnesses for my 59 Ply convertible.
Main harness-495.00 tail light including top motor wiring- 210.00 courtesy light harness 30.00 That should cover my car. John
58 Coronet:
You are correct...there are two dimples on the interior of the light socket (can be seen in above photos) which hold the lens bezel in place.
John,
The holes for the lights in the Rear side Panels are located as follows:
The hole is 1 1/16" in dia.
The first photo Dim is 2 7/8" from the Horz. shelf as shown
The 2nd photo Dim. is 3 3/4" when you wrap with the contour as shown.
The last photo show that the panel is Dimpled about 1/8" in to except the flange of the socket, This can be hard to do, you might just try mounting it flush or you could put a little padding under the vinyl to make up for the flange?
If you need anything else ,just ask
Mark
Mark
Thanks Mark. That explains a lot. I could not see not how the socket could mount on the curved surface but that dimple as you called it gives a flat surface to mount to. I think I can duplicate that. I will wait until I receive my sockets before I try. I had to make the left pocket as it was missing and that was quite a challenge. I will need some information on the well as it was also missing. I think I should start a new thread for that in the near future. You could take some pictures of the well from all angles while you have it opened up. I don't know how to include a picture but will try including one of my home made pocket. ( for practice)
