John - Great job, won't be long now, I hope it's ready when John Q. and I show up in our Convertibles.
I am heading out now with mine!....Maybe this spring to Van Nuys for the Mopar Spring Fling and then Carlisle, So catch me at one of those places in 2013!
Good work John!
Good work John!
A bit more lead work, I had to redo the lead seam, as when the car was hit, it had buckled this upwards.
You do excellent work John........Wish i lived close so I could come and help ya!!
John - You are kinda like me. No bondo in my car, like you I use body filler. Have you checked out USC ALL METAL.
jason wrote:You do excellent work John........Wish i lived close so I could come and help ya!!
Thanks, Jason,
If you were here, I'd love to have your help! Someday we'll get to meet, I'm sure.
I haven't used the All Metal, but a friend of mine who has a restoration business in Cocoa, Florida, has highly recommended it as well. I still have a good quantity of 30/70 solder [probably left over from the '50's] so hopefully it will be enough to complete all my projects.Dick Koch wrote:John - You are kinda like me. No bondo in my car, like you I use body filler. Have you checked out USC ALL METAL.
Taking a break from the '59 currently, as i am fabricating lower quarter panel sections for a '58 Sweptside a friend owns, and welding them in for him. Rather time consuming.
Wow lookin good!
I saved the old quarter panel skins for a reason-Being the quarters on the car carried entry Fury trim, every trim hole had to be re drilled for Sport Fury trim. I was hoping the bottom line of trim holes would be the same, but no such luck.
After all the work I have done, I didn't want to risk screw-ups or damage by hauling the body to a blaster, so I bought a sandblast pot and wheeled the body outside. I blasted inside, outside, and anywhere I could see any rust, but carefully so as not to warp the metal. I did find a few pinhole areas, but none bad enough to make the metal weak. These will be leaded in when I resume with the body. I spent two full days doing this, not a pleasant job, but it's done.
Wow John - Looks great, considering what you started with my hat's off to you. Looks like at the pace you are going you'll be finished before me.
Fantastic Job,
Fantastic Job,
