Clutch rod grommet
Clutch rod grommet
Anyone have or know where I can get a rubber grommet for the firewall where the clutch rod passes through? It's oval and measures about 1 3/16" wide X 2 3/8" long. Thanks, Ron
Ron - Two possible sources, www.fremanauto.com in Whitehall Montana and/or Gary Goers at www.tomandgaryinc.com/garygoers/index.htm
Neil Freeman operates a old cars junk yard and has at least 10-13 59's in his yard, I saw them. Gary Goers has a on line catalog and is the main source of reproduction rubber parts for Mopar cars. Check them out,
Sorry Ron - That should be www.fremansauto.com I left out the s.
Re: Clutch rod grommet
Thanks, Dick. I just saw your links today and sent a request to Freman's. Gary Goers doesn't have a clutch rod grommet, but he's been a good source for other parts. Ron
