Question about A/C
Hi Dick, to my knowledge, the factory installed just the dash mounted A/C units. Dealer air had the under dash units, and at most shows, these are considered a 'correct' item. ---John
Thanks John - Thats what I thought, there is a guy on e-bay with an under dash unit that he took out of a 59 Plymouth, must have been dealer installed. He is parting out a 59 4dr. hardtop Fury.
Dick, if it is the same one I had seen from a seller in Colorado, it appears to be an aftermarket unit from the '70's. The Mopar units were more square, with three large round registers in the front. ---John
Big M John is correct..the factory only installed the in-dash units. If you have the 1959 Mopar Parts Book, there are "exploded" views of the various dealer-installed under-dash units. I'll send you a picture of the page if you want, Dick.
Hi Roger - I found the exploded view of the dealer installed under dash unit, its ugly, glad I have the factory unit.
1959Fury
Post by 1959Fury »
Dick Koch wrote:Hi Roger - I found the exploded view of the dealer installed under dash unit, its ugly, glad I have the factory unit.
Going on memory from a decade ago, but the '59 Fury I almost snagged had the under dash dealer A/C - black, rounded corners and round white vents on the front and sides.
Does your exploded view pic look anything like that?
Always remember to keep one foot in the groove
No, In the 59 parts book page 24AG it shows a Model D system, it is a large rectangular unit with square edges and three large round registers in the front, none on the sides.
