Valve stem seals
Valve stem seals
I need a set of Valve stem seals. The seals that came with the engine gasket set are wrong as well as the valve stem seals sold individually supposedly for 59 318 two barrel. Can any body tell me where I might get the correct ones or ones that would work? Thanks in advance
Re: Valve stem seals
Try Rockauto.com
Just search for plymouth / 1959 / fury / 318 / engine
On the bottom it has the valve stem seals.
They show pics so you might be able to pick the correct ones.
Hope this works!
Hope this works!
Thanks Mathew, I need to remember Rock Auto.Matthew Keij wrote:Try Rockauto.com
Hope this works!
So do I! Keep forgetting about them.
Did you found the correct ones?
