Dual antennas for the rear trunk deck
Re: Dual antennas for the rear trunk deck
thanks for trying to explain, but I don't have any idea what you are talking about
Hi Roger, It was on the dual antennaes and to look for the flat or the angle bases and then we morphed to the angled gaskets bases that go with the angled antennae bases. I happen to have a set of original angled base gaskets and Dick Koch wanted to see them.
I posted the pic's so others can see them too!
Check out the eBay link I posted with the antenna's. Looks like the antenna bases are the same height on both side. If they are you jeednthe gaskets John has.rogerh wrote:thanks for trying to explain, but I don't have any idea what you are talking about!
Most antenna's have a thicker base on one side so they are angled. With this you need a flat gasket.
