Widest rear tires that fit 59 Belvedere without cutting
Posted: Wed May 31, 2006 9:27 am
by Big Jimbo
I am in the process of installing a larger engine in a 59 Belvedere and will need some bigger rubber. I was wondering what other people have found that fits. I was thinking of something like 255/55/16 for the rear. Any suggestions for the front would also be helpful.
Thanks!
![Smile :)](./images/smilies/icon_e_smile.gif)
Posted: Sun Oct 15, 2006 4:10 am
by matty
Dont know the answer to your question but i would like to know the answer myself as i am going to fit a stroked 400 b block in my 59.
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Posted: Thu Jan 25, 2007 4:44 am
by sportfury1959
Jim,
The size of the stock rims on some cars is 5”x14” on others it is 5.5”x14”. The rims on my car are the original ones (14”) but I’ve “opened” them to 7” width. I’m pretty close to the edge now (without cutting).
- The front rims are “opened” with a negative offset - the rim goes more to the outside, otherwise it would touch the upper control arm. Also the tire would touch the inner fender, when the steering wheel is fully turned to one side.
- The rear rims have a positive offset – the rim goes more to the inside, otherwise the tire would touch the fender.
The most challenging thing was to widen the rims that they fit over the callipers. Since you want to go for 16” rims that won’t be a question for you, but you have to consider another problem. Our cars have leave springs on the rear and that means the tail pushes sideways over the rear axle when you drive curves. An offset of 1” to 1.5” to each side is easily possible and then the tire touches the fender or fender-skirt. To make it safe you might need a Panhard-bar.
Let me hear about your progress!
Posted: Thu Jan 25, 2007 10:46 am
by savvy59
It is hard to answer this question because there are a few items missing from your request.
Do you plan to change the rear in the car?
Do you plan to go to a custom wheel since you have upgraded the motor and the car is no longer original?
I said this in another post, but
I changed to a 1976 Volare 8 1/4 3:23 Posi-Rear. I used 16 x 7 Centerline Fluted Hawk Rims with 3.5" offset. I mounted 225-55-R16 radial T/A tires for the back and 205-55-R16 tires in the front (same rim size).
There is still room left in the rear side to side, but since my car was lowered the problem came when you tried mounting the rim and tire to the car. There was just enough room to fit the tire between the car fender and drum.
I hope this helps.
Curt in MD
Posted: Wed Feb 07, 2007 3:54 pm
by Big Jimbo
Thanks for your replies, Curt and Stefan! I am going to install a Dana 60 in the rear but would like to keep a relatively stock appearance. I was thinking of using a 15 or 16 inch chrome wheel, but I sure like the looks of those Centerline wheels! It sounds like the 7 inch wide wheel will be the right size.
Jim
Posted: Wed Feb 07, 2007 6:03 pm
by savvy59
Jim,
Just to think a few years back when I went from stock 14" rims to 16" Centerlines the car looked like it had all rims and no tires. Not the case any longer with these huge wheels I see everywhere (Barrett/Jackson auctions).
I must say I love the look and I have had them about 7 years. Clean simple design that is easy to keep clean.
Good Luck with your restoration.
Curt in MD.
Posted: Thu Feb 08, 2007 4:31 am
by sportfury1959
Hello,
There’s one thing I want to add. Curt is right, it’s possible to use wider rims on the rear if you don’t use the original „cone style“ hub caps. They protrude the rims and take also some clearance away.
