59 Belvedere driver side trim/pushbutton knobs/dual antennas
hawkeye999
Post by hawkeye999 »
I'm restoring a 1959 Belvedere 4-door sedan and am looking for:
1. Driver side exterior trim. I would consider buying the whole side if you have it, but here is what I am lacking:
- Upper stainless trim
front fender
front door
- Middle trim (stamped anodized aluminum)
front fender
front door
- Lower stainless trim
front fender
2. Powerflight push button caps/knobs (all 4 R,N,D,L)
3. Dual rear antennas :lol:
4. Radio on/off stem
Thanks much,
59plymouth59
Re: 59 Belvedere driver side trim/pushbutton knobs/dual ante
Hawkeye - I probably have most of your trim needs, have to sort it out and get back to you.
hawkeye999
That would be great, Dick. I rechecked the driver side again and all of the lower stainless trim I have is in good shape. I would like to replace all 4 pieces of the upper stainless trim (but could live with the rear fender piece I already have). As for the middle anodized aluminum, I think I only need the rear door piece (some jackass cut one end at a notched angle for some reason, but at least I can use that one to cut the small knife-shaped piece I need for the front fender). My front door piece should be OK, but let me know if you have a replacement for that as well.
Thanks again,
Jim
