Whistling Plymouth
Whistling Plymouth
Last week while driving back 50 miles from a car show my SF (engine) started whistling, only when de-accelerating or at idle. Got home and did a quick visual check. Didn't see any vacuum hoses disconnected. Next day started her up for a minute and no whistling. Figured I'd have to drive it a ways for a good test so yesterday, drove her a good 50 miles. No whistling, ran good. You'd think a vacuum leak just wouldn't go away by itself. :?:
savvy59
Re: Whistling Plymouth
Post by savvy59 »
On the other hand - vaccum lines are cheap! If you are like me - I say they should not be leaking - I just changed them, and it turns out to be they were changed 10 or more years ago! That happened in 2008 Carisle when my chrome Holley fuel pump quit. I thought it was rather new but soon realized it was installed in 1996 :oops: Of course the Netherlands group came to my rescue and installed a stock 318 pump in 94 degree heat.
Good luck searching and replacing - I am certain you will find the culprit!
Just my 2 Cents.
I would also check vacuum lines first. If you have power brakes, the large vacuum hose can crack, only whistling at certain times. Had this happen before myself.
Thanks, guys. Never think of replacing vacuum lines. Mine have to be decades old. Kinda reminds me of lock washers. Take something apart and just naturally reuse the old lock washers. Had a tranny loosen up on me a few years back....I blame the reused lock washers.
Years ago I had a mysterious whistle, I traced to my vacuum operated brake booster control valve, on the pedal side. I sprayed it with an inexpensive penetrating oil,' Tri flo a Teflon infused light weight oil' the whistling ceased after the first application of the brakes. I also had a friend that had installed his carburetor gasket 180 out of the intended position. This took years to start whistling. After installing a new base gasket correctly for him he said 'The old Plymouth ran better than it had for years.' Imagine that.
