headliner time
headliner time
I hope to get Faulkner back from Bill in a week or so -- then, I'm going to work on getting the headliner fixed. I bought this vinyl material:
http://www.wlsheadliners.com/off-white- ... 89300cb83e
I have Caravan headliner strips to hold the panels in place:
http://59plymouth.net/59forum/viewtopic ... ht=caravan
And I got some very nice strip ends from Tom Fox. Hmm... Maybe I'll get my painted side rails (from John Fowlie) chromed... I wonder if I can pull this off before Carlisle? I guess I can always fall back on using Roger's forks...
So how is that gonna work...do you plan to glue the vinyl to the existing hardboard?
If you are abandoning the panelboard, be prepared for a massive test of your patience..trying to install headliner so that it looks good is better left to professionals, IMO! If I needed the job done, I'd get the rails chromed, then I'd take it all to an upholstery shop!
My guess is that we will need forks again this year How about putting the medallions on the fins this year Dan?Nighthawk wrote:I agree, its a thankless job if you dont know how to do it, and its also my understanding that on Plymouths you have to remove the rear window glass to change the headliner.......
Bob
Actually, the (replacement) panelboard seems to be in good shape -- just needs to be trimmed, methinks. I was planning on reusing it.rogerh wrote:So how is that gonna work...do you plan to glue the vinyl to the existing hardboard?
Huh? I think the panels are tucked under the rear trim. No?Nighthawk wrote:I agree, its a thankless job if you dont know how to do it, and its also my understanding that on Plymouths you have to remove the rear window glass to change the headliner.......
Bob
Dunno! Faulkner ain't here for me to run take a look at!
sorry to be dense, but what is the perforated vinyl for, if you have replacement panelboards (don't tell me you paid Mopar Mel's price!)
I havent had a hardtop for some time, but I do recall the sedans had only rubber on the rearw windows, so you had to deal with some fit challenges.
Do I remember correctly that with the Sport Fury hardtop, there is an actual chromed garnish molding at the ceiling-to-back window intersection? Perhps my parts book would show...
I'm pretty sure there's a chrome upper rear window garnish, Roger -- because I recall what a bad fit the upholsterer did. But someone else will have to weigh in, or I'll have to wait for Faulkner to come home to know for sure.
My original panels are gone; the upholsterer made some decent replacements, they just need to be trimmed a bit, I think. I don't like the material that's on there. 'sides, there's some spaghetti sauce on it -- now, who got the raviolis-to-go with a plastic fork at the quickie-mart?! (kidding!)
- sportfury1959
- sportfury1959
- sportfury1959
Wow Stefan - what a complete description of replacing a headliner in a hardtop car. My headliner is original and still intact (although a little dry to the touch). I have not attempted to have it replaced as I have a sedan that requires the rear window to be removed and the headliner tucked under the larger rear window rubber moulding.
I always think that I have done a lot of work to my car until I read these posts and I am put to shame. I have been lucky with my car because it was a low miles car and in pretty solid shape when I bought it 17 years ago!
Now if I can just get this 600CFM Edelbrock installed and the car cleaned up before Carlisle!
Thanks again for the headliner lesson.
- sportfury1959
- Fins59
I replaced my center piece in 2004. I read quickly thru above posts so don't know if this was covered but I did not remove any glass. It was a simple procedure. Removed old center piece by removing the 2 strips and removing the chrome trim pieces at rear window and windshield. Cut new panel board to correct size. (make sure front and rear will fit under chrome trim) Ensure fit, then glue the perforated vinyl to panel board. Glued/attached to ceiling sheet metal, by factory, was/is a few, what looked to be rubber pads. These pads are what your new piece will be glued to. With the help of a helper, glue new center piece to these pads, then attach new strips (I used my old ones) and reattach front and rear chrome trim by the glass and you're done. My side panels were a little "flaky" so I lightly sanded them with steel wool or fine sandpaper (can't remember, maybe both) and then sprayed them with a white craft spray paint. Turned out pretty good, imho. I think I noticed your new vinyl was padded. I don't think the original was and my new vinyl is not padded. Don't know if this would make a difference. I think I required 2 yards. When you glue vinyl to panel board be sure to have a generous amount on top of panel board. As a side note, just before I did my headliner I had my sun visors redone by a local guy for $90. They required padded vinyl.
