transmissions
sportfury1959
Post by sportfury1959 »
I simply followed your advice and visited the allpar site. I already did that before but I couldn’t find anything. Maybe I wasn’t persistent enough. Here is the page I found yesterday:
http://www.allpar.com/mopar/torqueflite.html
The A-488 is mentioned in the 4 line top down.
PS: Anyhow we know now that it’s called A-466 or A-488. It’s not likely that Chrysler built two different Torqueflites at that time. (Maybe A-466 is the Powerflite?)
sportfury1959
Hi Roger,
just stumbled over this old post. You are right, it's the A-466 and I've got this information exactly from this allpar-site
wipe
Re: transmissions
Post by wipe »
guest wrote:Hello, I am trying to find technical information on the three speed column shift manual gearbox (with overdrive?). Can anyone tell me about it or point me in the right direction. Thanks
I have just repaired 3 speed manual gearbox with overdrive (B&W).
I have that gearbox manual in Pdf form, if you are intrested I can mail it to you.
That includes also wirings for the function of automatic overdrive.
Plymouht Savoy- Life with style since 1959
Re: transmissions
wipe wrote: I have just repaired 3 speed manual gearbox with overdrive (B&W).
Hey Ville, attach it here! I'd like to see it too. If it's more than 2MB, let me know and I'll up the posting limit.
wipe
Post by wipe »
Ups, I almost forgot...
Here is link to B&W Overdrive manual, it helps to understand how the transmission works: http://kotisivu.dnainternet.net/wiper/BW_OD_Info.pdf
